Diagrams
Diagrams
Working with Diagrams
Area Shape
: Defining Area Shapes
Area can be represented by any 2-dimensional shape which is imported on a stencil as Area Shape using the Import Shape Wizard. After that it can be used as any other item by dropping it on the drawing. Area Shape can be located on the foreground and background page.
An Area Shape can be used just as a graphic frame not connected to any database element or it could have database representation. DB data against the Area Shape are stored as SCAREA element, which can be created below SCGROU. As any other element, Area can be defined in DB using
Define
command and also it can be defined on dropping the shape on drawing. To allow the second possibility,
Define Area on Drop
settings should be set to
True
The option is only applicable when
General options->System configuration->System->Define shape on drop setting
is set to
True
To disconnect Area Shape from database element
Undefine
command can be used. It is possible to specify different colours for defined and undefined Area shapes - see picture above.
The Primary/secondary shape mechanism can be used to contain several Area Shapes on different drawings referring to the same SCAREA element. For more information please see
chapter
Primary / Secondary Shapes
Elements contained by defined Area Shape are referring to it via SCAREF. One item can refer to several Area Shapes. All items referring to SCAREA via SCAREF can be seen in Schematic Explorer tree as its secondary hierarchy:
By default the Area has the attributes relevant for the SCAREA element, but the set of attributes controlled by Area Shape can be extended in
Diagrams Options.
Select
the
Attribute Presentation
click the
Referenced Attributes
button and then manually key in the attribute names:
