Diagrams User Guide
Diagrams : Utilities : Gateway Mapping : Engineering Mapping : Class Mapping : Basic Class Mapping
class name of diagram elements that the data is mapped from. It is an element TYPE, which is typically used in Diagrams. This field is always required. There is also a special ALL value for this attribute (details in notes).
untag - resulting EIWM object will not have tag hotspot (SVG) in related published drawing.
ignore - classes having this modifier will not be published at all (No EIWM object and no tag hotspot published for elements of this type).
onlytag - this modifier means that Only element tag hotspot (SVG) will be available after published and no EIWM information.
All Diagrams elements from the table are outputted to the EIWM and SVG tag (if visible) by default. This behaviour can be changed by adding a specific modifier attribute to any class mapping.
There is also one Diagrams element that is not listed in the table but also has its default behaviour:
:Notes:
is the default context value taken from Gateway DiagramsConfig.xml file.
is the document class setting taken from Gateway DiagramsConfig.xml file.
is the Diagrams page element which is being published at the moment.
is the Diagrams element which is currently (Current Element) being processed when publishing page.
Current default behaviour of drawings published to AVEVA NET Workhub Dashboard is to tag (hot spot) branch elements (tubes, fittings, instruments), with branch Object ID, with the exception of valves. This behaviour can be modified by using advanced class mapping described in later sections.
The special ALL value for the from attribute in class mapping can be used for overriding default Class ID for all unmapped elements if included in class mapping configuration file as shown below:
