Diagrams User Guide
Diagrams : Utilities : DWG Export : User Interface : Layers Tab
The Layers tab contains a set of DWG layer properties; Colour, Line Width and Line Pattern. If the Line Pattern box ByLayer is ticked, every shape that belongs to the specific layer will have the corresponding property set to ByLayer. This means that the value in the layer property will control that of the shape(s). The Refresh button refreshes layers from the active diagram.
The Layers Map tab (Figure 10:16.: Layers Tab) contains the following controls:
Refresh button - refreshes layers from the diagram.
Figure 10:16.
