Diagrams User Guide
Diagrams : Utilities : DWG Export : User Interface : Lines Map Tab
Lines Map contains pairs of Visio lines types and DWG line patterns that shows line type representation in DWG after export. Available DWG lines are defined in the Diagrams.lin file. A description of how to define DWG line patterns can be found in Creating Line Patterns below.
The Lines Map tab (Figure 10:15.: Lines Map) contains the following controls:
Line types table- table with corresponding lines patterns from Diagrams to DWG.
New - add new rows to the map table.
Delete - delete selected rows from the map table.
Default - option to choose default DWG pattern.
Refresh - refreshes DWG patterns list. Refresh must be used every time the Diagrams.lin file is changed so that the DWG line patterns will be available in the lines map grid.
Figure 10:15.
