Export location - path to exported DWG file. On the right hand side there is a button for choosing the right path from the dialog. If full path is not used, the export will create the DWG file in the %PDMSEXE% directory
DWG version - option to fit valid version of exported DWG file.
Exported shapes - option with shape collection manners for exported diagram.
Page (default) - collects all shapes from the active page and background page(s).
Selected - collects all selected shapes from the active page and all from the background page, if the background page is not the active page. The order of selection determines the order of export.
Units - option for choosing metric or imperial units to be used in the DWG file.
Line type scale - the LTSCALE variable is used to control the line type scaling factor of all displayed objects.
Export attributes - determines whether attributes stored in shape data will be exported or not. By default this option is enabled. Disable it to improve performance.
