Go to Manage > Set Active Cases where all the cases created in Engineering are listed. By default the base case is checked. Depending on the selected cases the annotation displays the attributes of the cases.
The Set Active Cases finction is by default disabled. It is enabled on opening the drawing.
Click Options > Create to create a new configuration of the same type of element which was created in Engineering.
Use the Shift Key to drag and drop the shape that should be associate with the unassigned item. A new Schematic database element is created in the
Schematic Explorer.
Go to Component Properties in the
Context Sensitive menu to display the Engineering attributes of the linked element. The option is enabled depending on the settings in
Diagrams Options.
Click on the Component Properties. A window with two tabs is available. In the
Case Data tab all the cases attributes are displayed.
