The AVEVA NET Gateway for IE&D is an add-in to AVEVA DiagramsTM that must be installed separately. Click the
AVEVA NET Export Setup button to access the gateway from AVEVA Diagrams
TM:
The AVEVA NET Export Setup window is part of the AVEVA NET Gateway for IE&D (gateway) and enables you to publish data from AVEVA Diagrams
TM to AVEVA NET Dashboard (AVEVA NET). The gateway replaces the AVEVA NET Gateway.
Use the AVEVA NET Export Setup window to create a configuration based on which data can be exported to AVEVA NET. For information about how to create configurations, refer to the user guide.
