Line types table- table with corresponding lines patterns from Diagrams to DWG.
Line Scale - Line Scale is used to control the line type scaling factor of all displayed objects.The Line Scale will override the settings tab Line type scale.
New - add new rows to the map table.
Delete - delete selected rows from the map table.
Default - option to choose default DWG pattern.
Refresh - refreshes DWG patterns list. Refresh must be used every time the Diagrams.lin file is changed so that the DWG line patterns will be available in the lines map grid.
Figure 10:14.
