SizeDefault Property
Gets or sets a value indicating whether the default system metric cursor size should be used
when loading.
[Category("Cursor Sizing")] [Description("Determines whether to use default system metric size for the cursor. If this property is 'true' and the SizePreferred is (0,0) the default system metric size for cursors is used. If this property is 'false' and the SizePreferred is (0,0) then the actual size of the cursor is used (if the cursor contains multiple sizes then the first is used).")] [DesignerSerializationVisibility(DesignerSerializationVisibility.Visible)] [RefreshProperties(RefreshProperties.All)] [DefaultValue(true)] public bool SizeDefault {get; set;}
[Category("Cursor Sizing")] [Description("Determines whether to use default system metric size for the cursor. If this property is 'true' and the SizePreferred is (0,0) the default system metric size for cursors is used. If this property is 'false' and the SizePreferred is (0,0) then the actual size of the cursor is used (if the cursor contains multiple sizes then the first is used).")] [DesignerSerializationVisibility(DesignerSerializationVisibility.Visible)] [RefreshProperties(RefreshProperties.All)] [DefaultValue(true)] public: property bool SizeDefault { bool get(); void set ( bool value); }
true if size default, false if not.Exceptions
| Exception | Description |
| System.Exception | Thrown when an exception error condition occurs. |
