OnlineLinkCommand Class Members
The following tables list the members exposed by OnlineLinkCommand.
Public Constructors
![]() | OnlineLinkCommand Constructor | Default constructor. |
Public Fields
![]() | Execute | Overloaded. Executes the given document. |
Public Events
