NavigationMenuSelectCommand Class Members
The following tables list the members exposed by NavigationMenuSelectCommand.
Public Constructors
![]() | NavigationMenuSelectCommand Constructor | Initializes a new instance of the Aveva.ApplicationFramework.Presentation.NavigationMenuSelectCommand class. |
Public Fields
![]() | Execute | Overloaded. Executes. |
Public Events
