TextFileConfigurationProvider Class Members
The following tables list the members exposed by TextFileConfigurationProvider.
Public Constructors
![]() | TextFileConfigurationProvider Constructor | Constructor |
Public Fields
![]() | CreateIfMissing | CreateIfMissing (Inherited from Aveva.ApplicationFramework.BaseConfigurationProvider<TS>) |
Protected Fields
![]() | AutoPrefix | Auto qualifier prefix (Inherited from Aveva.ApplicationFramework.BaseConfigurationProvider<TS>) |
![]() | GroupNames | Group Names (Inherited from Aveva.ApplicationFramework.BaseConfigurationProvider<TS>) |
Top
Top
Protected Methods
![]() | AddGroupIfRequired | Adds a group if required. (Inherited from Aveva.ApplicationFramework.BaseConfigurationProvider<TS>) |
![]() | AddGroupsIfRequired | Add Groups from key if required. (Inherited from Aveva.ApplicationFramework.BaseConfigurationProvider<TS>) |
![]() | ConfigurationExists | Check if configuration exists (Inherited from Aveva.ApplicationFramework.BaseConfigurationProvider<TS>) |
![]() | Finalize | Allows an object to try to free resources and perform other cleanup operations before it is reclaimed by garbage collection. (Inherited from Aveva.ApplicationFramework.BaseConfigurationProvider<TS>) |
![]() | GetValue<T> | Get Value by name (Inherited from Aveva.ApplicationFramework.BaseConfigurationProvider<TS>) |
![]() | ProcessLine | Overridden. Process a line. |
![]() | SafeName | Safe name (Inherited from Aveva.ApplicationFramework.BaseConfigurationProvider<TS>) |
![]() | SetValue<T> | Set Value (Inherited from Aveva.ApplicationFramework.BaseConfigurationProvider<TS>) |
![]() | ValueAsString<T> | Overridden. Value as string. |
Public Events
![]() | AddConfigurationEvent | Update event handler raised when configuration added to provider (Inherited from Aveva.ApplicationFramework.BaseConfigurationProvider<TS>) |
![]() | RemoveConfigurationEvent | Update event handler when configuration removed from provider (Inherited from Aveva.ApplicationFramework.BaseConfigurationProvider<TS>) |
