Structural Design User Guide
Stairs, Ladders and Handrails : Stairs, Ladders and Handrails Tools : Split Rails
By default, the Clearance of the split rail is 0mm and the Cut Plane check box is selected.
To split the rail using an existing element in the 3D model, from the Split Rails window, click Split Rails on Element, you are prompted to Pick the element on which to split the rails/kickplates.
To split the rail between 2 points in the 3D model, from the Split Rails window, click Split Rails between 2 points, you are prompted to Pick rail or kickplate to split.
Once the rail/kickplate is picked in the 3D view, you are prompted to Pick split position (Distance [0]) Snap: The selected rail/kickplate is split between the picked points.
