Structural Design User Guide
Stairs, Ladders and Handrails : Modify Stairs, Ladders or Handrails : Modify Handrail
All of the HANDRA modification tasks are initiated from a central Modify Handrail window which acts as a task hub.
The functionality available for the Modify Handrail window is identical to the Create Handrail window. Refer to Create Handrail for further information.
If you attempt to modify a Layout mode handrail element from the Modify group, an error message displays summarising the problem.
Modify the handrail as required, click Modify Handrails, a Confirm window displays:
Click Yes to remove any previously added details.
Click No to discard any changes.
Click Cancel to discard any changes and close the Modify Handrail window.
