You are prompted to Pick route point to make current
You are prompted to Pick new position for current route point (Distance [0]) WP Snap:
You are prompted to Pick first route point of sequence to be deleted
Once the selection has been made, you are prompted to Pick last route of sequence to be deleted#
Once the selection has been made the route points are deleted, you are then prompted to Pick position of new route point (Distance [0]) WP Snap:
Deletes all the route points of the handrail, you are prompted with a Confirm window: Delete all route points?.
You are prompted to Pick position to insert gate (Snap) Snap: and the Positioning Control window displays. Refer to Positioning Control for further information. Once the new position is selected in the 3D view, the Openings part of the Create Handrail window is populated with coordinates of the Opening.
You are prompted to Pick new position for gate (Snap) Snap: and the Positioning Control window displays. Refer to Positioning Control for further information. Once the new position is selected in the 3D view, the Openings part of the Create Handrail window is populated with coordinates of the Opening.
