All of the HANDRA creation tasks are initiated from a central Create Handrail window which acts as a task hub. The
General Attributes window is always initially displayed, regardless of the selected SLH element or representation mode, further windows are presented (progressive disclosure) prompting for input.
Layout is a basic representation of the intended handrail. The database only contains the handrail and its intended route plus any openings for gates, the handrail does not own any detailed components. Refer to
Layout Handrails Hierarchy for further information.
From the General Attributes part of the
Create Handrail window, select a default specification from the drop-down list of available specifications, if there are no default specifications, you must contact the administrator.
In the Name field, type the name for the new handrail, or select
Autoname Handrail.
The Height field is automatically populated with the default height of the handrail, once the default specification has been selected.
Use the Single Rail check box to specify if the single handrail is to be wall mounted or floor mounted. Select the
Single Rail check box, then
Wall Mounted or
Floor Mounted.
Click Cancel to discard any inputs and close the
Create Handrail window.
The Handrail Details part of the
Create Handrail window, is populated with the standard defaults for the handrail.
Use the Kickplate part of the
Create Handrails window to specify the inclusion/exclusion of a kickplate in the layout handrail and the kickplate type.
Irrelevant of the method used, when defining the route, the Finished Floor Level (FFL) and at least two route points must be defined. From the Route Definition part of the
Pick FFL. You are prompted to
Pick Finished Floor Level. It is usual to pick a horizontal surface, where the
FFL field in the
Create Handrail window is automatically populated.
Use the Route Points part of the
Route Definition window, to create the route points for the handrail.
Select Create Route Points, you are prompted to
Pick Position of first route point (Distance [0]) WP Snap: in the 3D view. Once the point has been selected, you are prompted to
Pick Position of new route point (Distance [0]) WP Snap: in the 3D view and you have access to the
Route Point Tools functionality. Refer to
Route Point Tools for further information.
The Copy Route Path functionality allows you to trace existing profiles or boundaries to use as a route path. For example: extrusions, panels, floors, GENSECs, walls and stair flights.
Click Yes to copy the route path of the existing profile or boundary or click
No to discard any inputs.
Use the Openings part of the
Create Handrail window to create an opening for the layout handrail. Refer to
Openings for further information.
Click Build Handrail to create the handrail in Layout mode.
