Structural Design
Stairs, Ladders and Handrails
Rung Ladder
: Detail Rung Ladder Hierarchy
When the RLADDR element is created in detail mode, below the administrative SLH elements, the RLADDR specific elements are:
RUNG LADDER (RLADDR)
The Ladder element (RLADDR) is a top level administrative element owned by other SLH administrative elements. For example, STRU, FRWM and /or SBFR.
RLCAGE (RUNG LADDER CAGE)
The RLCAGE element is an administrative element which owns the Cage Segment (CAGSEG) element.
CAGE SEGMENT (CAGSEG)
The CAGSEG element owns the GENSEC and PANEL steelwork elements used to 3D model the physical representation of the cage. By default, there are two cage segments, one representing the entry/exit at the top of the ladder and the other representing the remainder of the cage itself. The mechanism allows the entry/exit detailing of the cage to be modified individually from the remainder of the cage.
LADDER STRINGER (LDRSTR)
The LDRSTR element is an administrative element which owns the appropriate number of GENSEC steelwork elements used to 3D model the main supports of the rung ladder.
LADDER RUNG SET (RUNGSE)
The RUNGSE element is an administrative element which is used to manage the ownership of individual LDRRUN elements. The element is dependent upon the design of the rung and intended to support a variety of rung types.
LADDER RUNG (LDRRUN)
The LDDRUN element owns the GENSEC, PANEL or catalogue elements used to 3D model the physical representation of the rung.
