The functionality available in the General Attributes part of the
Create Stair Flight window is identical to that in
Layout mode. Refer to
General Attributes for further information.
The Reference Points part of the
Create Stair Flight window, with
Detail selected, has mostly the same functionality as that available from
Layout with the exception of the connections in the
Pick Support Element functionality. The functionality is also applicable to the ‘TO’ Reference Point.
Select the Connect check box to establish the connections.
Click Cancel to discard any inputs and close the
Create Stair Flight window.
The Stair Configuration part of the
Pitch Validation functionality.
From the Stair Configuration part of the
Create Stair Flight window, you can use the
X Offset and
Nudge functionality to move the stair flight element along the upper reference edge.
The Pitch Validation part of the
Stair Configuration window, allows you to modify the desired pitch and as a result the number of rises. It also provides the obtained pitch and an overview of the rise, going and validation for each rise.
The Obtained Pitch field within the
Stair Configuration window, displays the pitch that is obtained for the currently selected configuration.
The Extension and Landings part of the
Detail mode selected, has mostly the same functionality as that available from the
Layout mode with the exception of the Stringer functionality.
From the Stringer Options part of the
Create Stair Flight window, select the
Crank Bottom of Stringers check box (only for stairs to a plane). The stringers of the stair are cranked at the selected plane and displayed in the 3D view.
Extend Bottom Through Floor check box. The stringers of the stair are cranked at the selected plane and displayed in the 3D view.
The Specifications part of the
Detail selected, is populated with the specifications available for selection for the stringers and treads of the stair flight element.
Unlike Layout mode, adding handrails to a stair flight element in detail mode is a separate task using the
Create Handrails functionality. Refer to
Handrails for further information.
The Stair Summary part of the
Create Stair Flight window, is populated with the main attributes of the stair flight.
Click Build Stair Flight to create a new stair flight element.
