All of the STRFLT creation tasks are initiated from a central Create Stair Flight window which acts a task hub. The
General Attributes window is always initially displayed, regardless of the selected SLH element or representation mode, further windows are presented (progressive disclosure) prompting for input.
From the General Attributes part of the
Create Stair Flight window, select a default standard from the drop-down list of available defaults. if there are no defaults, refer to the administrator, the default is
Select.
In the Name: field, type the name for the new STRFLT element, or select
Autoname Stair Flight. The default is
Unset.
The Tread Width field specifies the tread width of the STRFLT element, it is automatically populated with the default of the selected standard (if set up by the administrator). If required you can amend the tread width of the STRFLT element within the minimum and maximum defaults.
Click Cancel to discard any inputs and close the
The Stair Summary part of the
Create Stair Flight window is populated with the tread width dimension of the STRFLT element.
To create a new STRFLT element, you must select a start (FROM Reference Point) and end
(TO Reference Point), from the
Reference Points part of the
Create Stair Flight window. By default no reference points are selected.
If you select the FROM Reference Point first, from the FROM Reference Point part of the
Reference Points window, select
Pick Edge (FFL). You are prompted to
SLH Stair Flight - Pick FROM Edge. Once the edge has been selected it is labelled as
FROM Edge in the 3D view.
From the TO Reference Point part of the
Pick Edge (FFL), you are prompted to
SLH Stair Flight - Pick TO Edge. Once the edge has been selected it is labelled as
TO Edge in the 3D view.
The Evaluation part of the
Create Stair Flight window is populated with feedback on the reference points. When the selected reference points are acceptable, a message displays:
The selected reference points successfully passed an initial check.
Create Stair Flight window, is populated with the Overall Rise, Going and Tread Width.
If required, you can modify the TO and
FROM Reference Points explicitly, the functionality to modify either edge position is identical. For the purposes of this guide, only the
FROM Reference Point is described.
To modify the FROM Reference Point position explicitly, from the
Create Stair window, select
Modify Position to display the
FROM Position window.
Click Offset to modify the position of the
FROM Reference Point as an offset value measured from the original position. Click
Return from offset mode to exit the offset display.
Click Apply to modify the position and close the
FROM Position window, or click
Dismiss to discard any changes and close the window.
Select the Up or
Down option button to define the direction of the stair flight from the point of origin.
By default, the Stair Configuration part of the
Create Stair Flight window is populated with all the allowable configurations allowed in the defaults.
The configurations that display in the Stair Configuration part of the
Create Stair Flight window are dependent upon which defaults are set by the administrator.
From the Stair Configuration part of the
Create Stair Flight window, input the offset distance into the
X Offset field then select
X Offset from.
The Positioning Control window functionality allows you to pick positions in event-driven graphics mode. Refer to
Positioning Control for further information.
Used for positioning the stair flight along the upper reference edge. Input the nudge increment into the Nudge field (default 100mm), click the arrows to nudge the stair flight along the X axis in the 3D view.
All of the configurations available for selection are displayed in the Stair Configuration part of the
Create Stair Flight window. By default, the configuration closest to the defaults is highlighted.
You can add handrails to the stair flight, from the Handrail part of the
Create Stair Flight window, select from the
Handrail Configuration drop-down list of available handrails.
The Extension and Landings part of the
Create Stair Flight window is populated with data for the new STRFLT element.
Some of the fields in the Create Stair Flight window are populated with the defaults set by the administrator and others are populated with results of calculations made by the SLH application using the defaults file.
The Extensions part of
Create Stair Flight window is populated with the lower and upper extension lengths (which are within the minimum and maximum default values) for the new STRFLT element.
The Landing part of the
Create Stair Flight window can be used to configure, add or remove the intermediate landing to comply with user/company standards or requirements and is dependent upon the selected configurations.
Use the dimension label from the Landing Options part of the
Create Stair Flight window, to display the length or height of the landing in the 3D view.
From the Rises Above or
Rises Below boxes, select the number of rises above and below the landing. If you change the number of rises above the landing the number of rises below the intermediate landing automatically adjusts within the height constraint and vice versa.
