Structural Design User Guide
Plates : Modify Panels : Merge Panels
You are prompted to Select first element to merge
You are then prompted to Select next Panel to merge
You are then prompted to Select next Panel to merge or <Finish>
Input F at the prompt and press Enter to end the command. The panels are merged.
Throughout the merge process you can press ESC to cancel the command. Additional functionality is also available.
