Press the down arrow key and select Justification to define the justification position of the fitting.
Input a justification value in the field and press Enter or press the down arrow key and select a justification value.
Press the down arrow key and select Angle to rotate the fitting.
You are prompted to Specify Angle <#deg>
Input an angular value in the field and press Enter or click to identify the angle of the fitting.
Press the down arrow key and select Repeat to create multiple fittings.
You are prompted to Specify position (Just: #) or <Finish>
Input a dimensional value in the field and press Enter or click to identify the position of the fitting.
Press the down arrow key and select Top outwards to create a fitting with top outward justification.
Press the down arrow key and select Top inwards to create a fitting with top inward justification.
Press the down arrow key and select Centre outwards to create a fitting with centre outward justification.
Press the down arrow key and select Centre inwards to create a fitting with centre inward justification.
Press the down arrow key and select Bottom outwards to create a fitting with bottom outward justification.
Press the down arrow key and select Bottom inwards to create a fitting with bottom inward justification.
