Press the down arrow key and select Depth to define the depth of the negative extrusion.
You are prompted to Specify the Depth <#>
The default depth value is identical to the associated panel thickness. Input a dimensional value in the field and press Enter to set the depth of the negative extrusion.
Press the down arrow key and select Surface to define the surface position of the negative extrusion.
Input a justification value in the field and press Enter or press the down arrow key and select a justification value.
Press the down arrow key and select Fillet to create a negative extrusion with a specified fillet.
You are prompted to Specify the Filllet <#>
Input a dimensional value in the field and press Enter to set the fillet of the panel.
Press the down arrow key and select Top to create a negative extrusion aligned to the top of the associated panel.
Press the down arrow key and select Bottom to create a negative extrusion aligned to the bottom of the associated panel.
Press the down arrow key and select Three point to create a disc negative extrusion with three specified points. Refer to Create Disc Negative Extrusion with Three Specified Points for further information.
Press the down arrow key and select Two point to create a disc negative extrusion with two specified points. Refer to Create Disc Negative Extrusion with Two Specified Points for further information.
Press the down arrow key and select Centre+ to create a disc negative extrusion with a specified centre point. Refer to Create Disc Negative Extrusion with Specified Centre Point for further information.
