Press the down arrow key and select Three point to create a disc panel with three specified points. Refer to Create Disc Panel with Three Specified Points for further information.
Press the down arrow key and select Two point to create a disc panel with two specified points. Refer to Create Disc Panel with Two Specified Points for further information.
Press the down arrow key and select Radius to create a disc panel with a fixed radius.
You are prompted to Radius (Thk: #mm, Just: #) or <Diameter>
Input a dimensional value in the field and press Enter to set the radii of the disc panel.
Press the down arrow key and select Justification to define the justification position of the panel.
Input a justification value in the field and press Enter or press the down arrow key and select a justification value.
Press the down arrow key and select Diameter to create a disc panel with a fixed diameter.
You are prompted to Diameter (Thk: #mm, Just: #) or <Radius>
Input a dimensional value in the field and press Enter to set the diameter of the disc panel.
Press the down arrow key and select Top to create a panel with top justification.
Press the down arrow key and select Bottom to create a panel with bottom justification.
Press the down arrow key and select Centre to create a panel with centre justification.
