Press the down arrow key and select Centre+ to create a ring panel with a specified centre point. Refer to Create Ring Panel with Specified Centre Point for further information.
Press the down arrow key and select Three point to create a ring panel with three specified points. Refer to Create Ring Panel with Three Specified Points for further information.
Press the down arrow key and select Justification to define the justification position of the panel.
Input a justification value in the field and press Enter or press the down arrow key and select a justification value.
Press the down arrow key and select Top to create a panel with top justification.
Press the down arrow key and select Bottom to create a panel with bottom justification.
Press the down arrow key and select Centre to create a panel with centre justification.
