Press the down arrow key and select Three point to create a ring panel with three specified points. Refer to Create Ring Panel with Three Specified Points for further information.
Press the down arrow key and select Two point to create a ring panel with two specified points. Refer to Create Ring Panel with Two Specified Points for further information.
Press the down arrow key and select Radius to create a ring panel with a outer radius.
You are prompted to Outer radius (Thk: #mm, Just: #) or <Diameter>
Input a dimensional value in the field and press Enter to set the radii of the ring panel.
Press the down arrow key and select Justification to define the justification position of the panel.
Input a justification value in the field and press Enter or press the down arrow key and select a justification value.
Press the down arrow key and select Diameter to create a ring panel with a fixed outer diameter.
You are prompted to Outer diameter (Thk: #mm, Just: #) or <Radius>
Input a dimensional value in the field and press Enter to set the outer diameter of the ring panel.
Press the down arrow key and select Top to create a panel with top justification.
Press the down arrow key and select Bottom to create a panel with bottom justification.
Press the down arrow key and select Centre to create a panel with centre justification.
