Structural Design User Guide
Plates : Create Panels : Create Arc Panel with Two Specified Points
You are prompted to Start diameter point or
Input values in the dimension fields and press Enter or click to identify the first diameter point position.
You are then prompted to End diameter point (Thk: #mm, Just: #) or
Input a dimensional value in the field and press Enter or click to identify the diameter of the ring panel.
You are then prompted to Specify panel width (Thk: #mm, Just: #) or
Input a dimensional value in the field and press Enter or click to identify the width of the panel. An arc panel is created and displays in the 3D view.
Throughout the panel creation process you can press ESC to cancel the command. Additional functionality is also available.
Press the down arrow key and select Centre+ to create an arc with a specified centre point and sweep angle. Refer to Create Arc Panel with Specified Centre Point and Sweep Angle for further information.
Press the down arrow key and select Three point to create an arc with three specified points. Refer to Create Arc Panel with Three Specified Points for further information.
Press the down arrow key and select Justification to define the justification position of the panel.
Input a justification value in the field and press Enter or press the down arrow key and select a justification value.
Press the down arrow key and select Top to create a panel with top justification.
Press the down arrow key and select Bottom to create a panel with bottom justification.
Press the down arrow key and select Centre to create a panel with centre justification.
