Press the down arrow key and select Fillet to create a panel with a specified fillet.
You are prompted to Filllet or <#>
Input a dimensional value in the field and press Enter to set the fillet of the panel.
Press the down arrow key and select Justification to define the justification position of the panel.
Input a justification value in the field and press Enter or press the down arrow key and select a justification value.
Press the down arrow key and select Top to create a panel with top justification.
Press the down arrow key and select Bottom to create a panel with bottom justification.
Press the down arrow key and select Centre to create a panel with centre justification.
