Structural Design
Sections
Modify Sections
: Merge Sections
Merge Sections
Merges two non parallel, colinear sections, regardless of specification, justification or beta angle.
If the sections are parallel, or not colinear, a Warning message displays on the status bar.
The properties of the merged sections are inherited from the first picked section.
You are prompted to
Select first element to merge
Click to identify the first section to merge.
You are then prompted to
Select second section to merge
Click to identify the second section to merge.
The sections are merged.
Throughout the merge process you can press
ESC
to cancel the command.
