Press the down arrow key and select Next to proceed to the next splice process.
Press the down arrow key and select Plane to splice a section using a plane. Refer to Splice Section using a Plane for further information.
Press the down arrow key and select LCS to splice a section at an alignment point with the origin of the local coordinate system.
