Press the down arrow key and select Next to proceed to the next split process.
Press the down arrow key and select Plane to split a section or panel using a plane. Refer to Split Section or Panel using a Plane for further information.
Press the down arrow key and select LCS to split a section or panel at an alignment point with the origin of the local coordinate system.
Press the down arrow key and select Plane to split a bounded plate using a plane. Refer to Split Bounded Plate using a Plane for further information.
Press the down arrow key and select Gap to create a gap between the split plates.
You are prompted to Specify gap width or <#mm>
Input a dimensional value in the field and press Enter to define the gap. The default is 0.
Press the down arrow key and select LCS to split a bounded plate at an alignment point with the origin of the local coordinate system.
Press the down arrow key and select Plane to split a bounding element using a plane. Refer to Split Bounded Plate Bounding Elements using a Plane for further information.
Press the down arrow key and select LCS to split a bounding element at an alignment point with the origin of the local coordinate system.
