Press the down arrow key and select Mitre only to mitre the section ends. The connectivity status of the mitred ends, is not changed.
Press the down arrow key and select Mitre and connect to mitre the section ends. The two mitred ends are connected.
Press the down arrow key and select Repeat to create multiple mitred section ends.
You are prompted to Select first section end to mitre or <Finish>
You are then prompted to Select first section end to mitre or <Finish>
