Press the down arrow key and select Perpendicular to section to extend a section end to align with the plane without cutting the endpoint.
Press the down arrow key and select Normal to plane to cut the endpoint of the extended section to align with the plane.
Press the down arrow key and select Next to proceed to the next extend process.
Press the down arrow key and select Panel to extend a section end to a panel intersection.
You are prompted to Select Panel to extend to or
Press the down arrow key and select Extend by value to extend a section end using an extension value, measured from the current position of the section end.
You are prompted to Specify extension or
Input a dimensional value in the field an press Enter to define the section extension value.
Press the down arrow key and select Overall length to extend a section end using an overall section length value.
You are prompted to Specify overall length or
Input a dimensional value in the field an press Enter to define the section length value.
Press the down arrow key and select Lcs to extend a section end to align with the origin of the local coordinate system.
Press the down arrow key and select Offset to create a plane that is offset from the picked points.
You are prompted to Specify offset
Input a dimensional value in the field an press Enter to define the offset value.
