Structural Design
Sections
Modify Sections
: Delete Merged Joint
Delete Merged Joint
Deletes a merged joint. The joints are returned to their previous state prior to being merged.
You are prompted to
Select owning section
The prompt does not display if the section element is already selected.
Click to identify the section that contains the merged joint to be deleted and press
Enter
. The merged joint is highlighted in the 3D view and is displayed as a merged joint pin.
The selection status of the merged joint is indicated by the merged joint pin colour.
Yellow = Not selected
Red = Selected.
You are then prompted to
Select joints
Click to identify the merged joint to be deleted and press
Enter
to delete the merged joint.
