Input True in the field to lock the section for modification.
Input False in the field to unlock the section for modification.
Displays the specification reference of the section which is populated from the Spec, Type and Profile fields.
True indicates that the section is a preferred specification.
False indicates that the section is not a preferred specification.
Input True in the field to define the section as mirrored from the position in which it was created.
Input False in the field to define section as not mirrored.
