Select from the drop down list to display all the available groups of fitting component available for the section. Once a specification has been selected from the drop-down list, the Fitting Group and Fitting galleries are automatically populated with fitting group and fitting components available for selection.
Select from the gallery to display all the available fitting components. Once a group has been selected, the Fitting gallery is automatically populated with the fitting components available for selection.
Select a fitting component from the gallery. Once a fitting has been selected, the Design Parameters fields are automatically populated with default values.
Click to display a detailed image of the fitting. The Image window displays a detailed description of the fitting geometry and the different parameters and variables that can be applied to the fitting.
Press the down arrow key and select Angle to rotate the fitting.
You are prompted to Specify Angle <#deg>
Input an angular value in the field and press Enter or click to identify the angle of the fitting.
Press the down arrow key and select Repeat to create multiple fittings.
You are prompted to Specify Distance or <Finish>
Input a dimensional value in the field and press Enter or click to identify the position of the fitting.
