Structural Design User Guide
Sections : Create Merged Joint
You are prompted to Select owning section
Click to identify the joints to be merged and press Enter to display the Merged Joint window.
The Merged Joint window allows you to associate a catalogue specification with the currently selected joints and modify the dimensions of the merged joint component parts.
An automatically selected joint is displayed as Unset in the specification and can be modified to a standard joint using the drop-down list.
Select from the gallery to display all the available joint components. Once a group has been selected, the Joint gallery is automatically populated with the joint components available for selection.
Select a joint component from the gallery. Once a joint has been selected, the Design Parameters fields are automatically populated with default values.
You are prompted to Select reference element
You are prompted to Set specification
Press Enter to associate the reference element with the merged joint.
Click Apply to accept the merged joint settings.
