Press the down arrow key and select Continuous to create multiple straight sections. The start point of each new created section is positioned at the end point of the previously created section. Refer to Create Continuous Straight Sections for further information.
Press the down arrow key and select Repeat to create multiple straight sections. You must define the start point and end point of each created section. Refer to Create Multiple Straight Sections for further information.
Press the down arrow key and select Mirror to reposition the section as a reflection of the original position.
Press the down arrow key and select Beta to rotate the section.
You are prompted to Beta angle
Input an angular value in the field and press Enter to set the angle of the section.
Press the down arrow key and select Parallel to orientate the web of the section parallel to the X, Y plane of the LCS.
Press the down arrow key and select Perpendicular to orientate the web of the section perpendicular to the X, Y plane of the LCS. The default creation mode is perpendicular.
Press the down arrow key and select Single to create a single straight section. Refer to Create Single Straight Section for further information.
You are prompted to Beta angle <#>
