The Connectivity Tolerances part of the
Structural Settings window sets the default tolerances for structural connections.
The Mitre Tolerance part of the
Structural Settings window sets the default tolerances for mitred sections.
The Joint Dominance Default part of the
Structural Settings window sets the default joint connection properties for connected sections.
The Stair Flight Calculate Mode part of the
Structural Settings window sets the default properties for creating edge to calculated position stair flights.
The Check Connection Colours part of the
Structural Settings window sets the default display colours for queried connections.
Click Reset to revert to the values applied when the
Structural Settings window was opened.
Click Apply to accept the default values.
