Structural Design
Structural Catalogue
Sample Fittings
: Fitting Type Codes
Fitting Type Codes
The table summarises the fitting type codes that are available in the catalogue
Fitting Group
Fitting Group Description
Fitting Type Code
Fitting Type
F1
Baseplates
SQR
Square/Rectangular
SWS
Square with Snipe
TRI
Triangular
CIR
Circular
F2
Stiffeners
WFS
Web Full Depth Single
WFD
Web Full Depth Double
WPS
Web Partial Depth Single
WPD
Web Partial Depth Double
FLS
Flange Single
FLD
Flange Double
TES
Tee Single
TED
Tee Double
F3
Lifting Lugs
BLT
Bolted
WEL
Welded
F4
Padeyes
WEB
Web Padeye
FPP
Flat Plate Padeye
F5
Shear Studs
SST
Shear Stud
F6
Scaffold Clips
SCC
Scaffold Clip
F7
Fireproofing/Insulation
FPI
