Structural Design User Guide
Walls and Floors : Modify Screed Slope
The Current Element part of the Screed Slope window allows you to select the screed element to apply the slope to.
The Position part of the Screed Slope window allows you to position a point through which the sloped surface passes.
The Slope part of the Screed Slope window allows you position the slope edge points.
You are prompted to Pick edge to slope from db Element:
You are prompted to Slope edge line, first:
You are prompted to Slope edge line, second:
The Settings part of the Screed Slope window allows you to define the slope contour, angle and direction.
To define the slope contour, from the Type drop-down list, select Straight or Conical. The angle of the slope normal to the screed plane must now be defined, input the slope angle in degrees into the Slope field.
Select the Lock check box to make sure that the angle is calculated so that the slope passes through the defined point.
Click Apply to display the outline of the new screed layout in the 3D view.
Click Cancel to close the Screed Slope window.
