Structural Design User Guide
Walls and Floors : Splice Wall
The splice can be applied to the CE, the current list or elements picked from the 3D view by the selection of CE, List or Pick from the options listed on the top left of the window. If the List or Pick option is selected, all of the elements selected are spliced at their intersection with the plane.
Select the Confirm before splicing check box to display a Confirm window before each splice occurs.
Click Apply, you are prompted to Identify walls to be spliced
If the Confirm Before Splicing check box was selected, a Confirm window displays.
Click Yes to splice the walls
Click No to discard any inputs and close the Confirm window.
Click Cancel to discard any information and close the Splice Wall on Plane window.
