Structural Design User Guide
Walls and Floors : Split Wall
The Split Walls window must be populated before any elements can be picked in the 3D view.
The only method to select Elements to be split on and Elements to be split in the 3D view is Pick using cursor.
From the Connections at split part of the Split Walls window, you can specify how the ends of the new shorter length walls are to be connected at the split points:
Select the Confirm before splitting check box to display a Confirm window before each split occurs.
Click Apply, you are prompted to Identify item to be split on
You are then prompted to Identify wall to be split
If the Confirm Before Splitting check box was selected, a Confirm window displays.
Click Yes to split the walls
Click No to discard any inputs and close the Confirm window.
Click Cancel to discard any information and close the Split Walls window.
