By default, Modify CE displays in the drop-down menu and the CE is described.
Alternatively, select Modify PICK from the drop-down menu to modify a fitting using a cursor pick in the 3D view.
The Floor Fittings window is populated with the specification data and positioning details of the identified floor fitting.
The functionality available from the window is identical to Floor Fittings window which is used in the creation of a floor fitting. Refer to
Create Floor Fittings for further information.
