By default, Modify CE displays in the drop-down menu and the CE is described.
Alternatively, select Modify PICK from the drop-down menu to modify a fitting using a cursor pick in the 3D view.
The Wall Fittings window is populated with the specification data and positioning details of the identified wall fitting.
The functionality available from the window is identical to Wall Fittings window which is used in the creation of a wall fitting. Refer to
Create Wall Fittings for further information.
