Structural Design User Guide
Walls and Floors : Modify Walls : Modify Wall Justification
To select the justification manually from the 3D view click Justification, you are prompted to Identify Pline to justify to, select the pline using a cursor pick in the 3D view.
Click Apply to accept the changes or click Dismiss to discard any inputs and close the Wall Justification window.
The modification procedure for the wall Member Line and Joint Line is the same.
