The functionality available from the Floor Fittings window is identical to that available from
Wall Fittings window (refer to
Create Wall Fittings for further information) with the exception of the Positioning part of the window (refer to
Reference Datum for further information).
From the Positioning part of the
Floor Fittings window, select the reference datum from the drop-down list.
The location of the fitting on the floor is set by the input of the X Position and
Y position. These two dimensions are measured from the origin of the owning wall indicated by the aid line in the graphic display.
Select Position fitting to display the
Positioning Control window, you are prompted to
Position Floor Fitting (Snap) Snap to position the fitting directly on the floor. Refer to
Positioning Control for further information.
Click Apply to insert the floor fitting or click
Cancel to discard any information and close the
Floor Fittings window.
The functionality available is identical to Floor Fittings. Refer to
Create Floor Fittings for further information.
