All the tasks that are associated with the creation or modification of wall fittings are initiated from a central Wall Fittings window which acts as task hub. Dependant on selections made in the
Wall Fittings window you are presented with further windows which prompt input.
By default the Create Standard option (single fitting) is selected.
From the Specification Data part of the
Wall Fittings window, by default
Electrical Fittings is selected. If another type of wall fitting is required, select from the drop-down list of available options.
The Current Selection part of the
Wall Fittings window, by default is empty. Dependant upon the selection of specification made, you are presented with a list of fittings available for selection from the catalogue.
When the Default check box is selected, only the fittings from the default specification are available for selection.
When the Auto check box is selected, the fitting is automatically selected, where only one fitting is available for selection.
If both the Default and
Auto check boxes are selected, the default fitting is automatically selected.
Once the Specification Data has been defined, the required fitting can be selected from the
Wall Fitting window.
The Owning Type part of the
Wall Fittings window is automatically populated with the types available for selection under the specification.
The Owning Type window automatically changes to the
Type window which displays a list of fittings. Click to select one of the items. The selected item displays in the
Current Selection window and a sub-section item displays in the
Type window.
Click the next selection in the Type window and the selected sub-section item appears in the
Current Selection window.
When the selection process is complete the Type window changes to
Selection Complete.
To modify the properties of the fitting, click Properties to display the
Modify Properties window. The name of the CE displays, by default.
Electrical Fittings: You can modify the Pline offset, which uses the Pline of a wall to calculate the offset between two elements that already exist.
Click Default to return to the default setting.
Click Reset to return to a previous setting.
Click OK to accept the modified properties.
Click Cancel to discard any inputs and close the
Fire Protection: You cannot modify any properties.
Standard Windows: You can modify the inset from the
Modify Properties window, the
Inset from the wall face can be set manually or select
Measure Inset from the wall face to pick the inset in the 3D view.
The Open Angle refers to the window opening angle in the representation of the window in the 3D view.
Standard Door: You can modify the inset from the wall face, from the Standard Door
Inset from the wall face can be set manually or picked in the 3D view, select
Measure Inset from the wall face.
The Open Angle refers to the door opening angle in the representation of the door in the 3D view.
Example Openings: You can modify the dimensions for the opening. From the Example Opening
Modify Properties window for General Rectangular Hole for Walls the X dimension, Y dimension, X offset dimension and Y offset dimension can be set manually or picked in the 3D view. Select the appropriate option.
From the Modify Properties window for General Circular Hole for Walls only the diameter can be Input or measured.
Click Default to go back the default setting.
To view a pictorial representation of the wall fitting, from the Wall Fittings window, select
Plotfile, to display the
Plotfile window. The plotfile functionality depends on the type of wall fitting selected:
From the Positioning part of the
Wall Fittings window, you must specify the distance offset from the outside or inside of the wall.
To position the fitting directly on the wall, click Position fitting to display the
Positioning Control window. You are prompted to
Position Fitting (Snap) Snap. Refer to
Positioning Control for further information.
The Sub-Fitting Orientation part of the
Wall Fittings windows allows you to orientate a sub-compound fitting relative to the owning compound fitting.
Click Apply to create the wall fitting or click
Dismiss to discard any inputs and close the
Wall Fittings window.
