Structural Design User Guide
Walls and Floors : Wall Connectivity : Tidy Joints and Nodes
Select the Mark Joint for Deletion, Delete Node if empty check boxes as required.
On the Tidy Joints window, click CE to identify the elements to be checked as the CE.
Select the Mark Nodes for Deletion check box as required.
On the Tidy Nodes window, click CE to identify the elements to be checked as the CE.
