Structural Design
Walls and Floors
Wall Connectivity
: Connect Walls
Connect Walls
Connects two wall ends. The selected wall ends are connected to make a corner.
A connection between two wall ends is facilitated by a Primary Joint (PJOI) element. The PJOI is owned by a Primary Node (PNOD) element, which is positioned on the justification line of the owning wall at the intersection between the attached and owning walls.
You are prompted to
First wall end:
Click to identify the first wall end.
You are then prompted to
Second wall end:
Click to identify the second wall end.
The wall connection process is repeated, allowing you to create multiple connections. Press
ESC
to end the command.
