Set the Justification to Bottom (this allows you to position the bottom face of the floor on the top of the supporting sections).
Set the Thickness, if a floor specification has been set, the default thickness is shown, entering a new value is permitted.
If a Confirm window displays, click
Yes to override the default thickness value and change it to Unset.
Click No to disregard the entered thickness value and retain the default value.
By default, Representation is set to Predefined: Default. These settings (Levels and Obstruction) affect the way items display in 3D views and how they are dealt with when checking for clashes between design items.
The Create Methods part of the
Create Floor window allows you to define each vertex.
Click Derive Points From Graphic Picks. The
Positioning Control window displays and indicates that you are now in event-driven graphics mode, ready to pick the position of the first vertex.
Pick the column and either of the beams whose intersection coincides with V1 in the diagram. From the Create Methods part of the
Create Floor window,
‘No vertices currently defined’ is automatically changed to
‘1 Vertices defined (no Floor created)’. After the definition of this first vertex,
Remove Previous Point becomes active. From this, you are able to delete the previous vertex definition.
‘1 Vertices defined (no Panel created)’ is automatically changed to
‘3 Vertices defined (Panel created)’.
As a demonstration, V4 is positioned relative to V3. Click Point Offset From Previous. The
Define vertex window displays in which you can specify the required offset.
Set the Direction and the
Distance, click
Apply to create the vertex, or click
Dismiss to discard any information and close the
Define Vertex window.
Create Floor window, is automatically changed to
‘4 Vertices defined (Floor created)’.
Click OK to complete the floor creation operation.
